Compression type fitting for copper to PVC?
Hello!
1" PVC pipe coming from the water company into my house. 1" copper piping inside the house at the first component (regulator). Tried a Sharkbite 1" connector, but they don't work on PVC (OD is too small). Anyone know of any connector (non-solder) that would work and a source for it?
I appreciate your help!
Regards,
Leaning
Regards,
Leaning
Cut and glue a male or female 1" adapter on the pvc coming in. Then convert from there.. With the sharkbite threaded on the pvc then you can just insert the 1" copper.. Hope this helps...
Then install shark bite adapter...
Lawrosa,
I appreciate your help, but I need it dumbed down a bit. Here's the current setup:
1) 1" PVC pipe coming through wall.
2) 1" PVC elbow
3) 1" PVC pipe section (cut off end)
4) 1" copper pipe (cut off end)
5) 1" male sharkbite (threaded)
6) 1" regulator inlet
7) regulator
So, I need to connect 3 to 4.
I considered using a 1" PVC to CPVC adapter, and then using the 1" sharkbite to connect 1" CPVC to copper, but I can't find a source for that adapter (3/4" yes, 1" no)
Hope the setup gives a better picture.
(I just thought about your idea, but there is much controversy AFA male PVC into female brass, or female PVC into male brass (because of different rates of thermal expansion leading to leakage, etc.) That's why I thought maybe there was a sharkbite-esque adapter for copper to PVC. Which would you recommend?)
Regards,
Leaning
2) 1" PVC elbow
7) regulator
Regards,
Leaning
Oh wait.....
(because of different rates of thermal expansion leading to leakage, etc.) That's why I thought maybe there was a shark bite-esque adapter for copper to PVC. Which would you recommend?)
I would thread a copper male adapter in the pvc adapter after I glues one on... with a solders stub out. Then sweat it with a coupling...
No difference in a brass fitting, plus its cold water right? Don't worry about t expansion...
There is no fitting that I know of for pvc to ??? except an adapter.. Then you can get anything with threads to adapt...( For water.. Waste lines are a different story)
I always use 2-3 wraps of teflon tape followed by a bit of PVC compatible pipe dope to ensure the connection is secure. It may be a bit overkill, but it works for me.
Regardless of whether you use a SharkBite or soldered copper, you're still going to need to use a threaded connection to convert PVC to copper.
