Natural Gas Pipe connections -
Extending existing gas supply to a new cooking area; is it necessary to use teflon or pipe dope on the screwed connections ; and any problem mixing iron and brass ?
Hello and welcome...
You are extending from where?
Are you tapping in somewhere? If so most likely you will/may starve other appliances of gas...
You could have co/draft issues..
I see no issue with brass and iron..
