Noisy Kitchen Drai
Old 03-14-01, 04:01 PM
Guest
Question
My kitchen drain gurgles after water has drained from the sink. It's kind of a gloop, gloop sound, and will go on for a few minutes, with the gloops getting further apart.
Where should I look for the problem? Drain partially clogged, or vent stack blocked? Some other possibility?
Thanks.
Old 03-14-01, 04:26 PM
L
Probably a partial clog in the vent, or where the vent is tied to the drain line itself. Run a hose with a brass spray nozzle, set at a hard stream of water, down the vent from the roof. That often times will clear the problem.
HTML code is On
