Problem when Disassembling Outdoor Faucet
Old 09-06-14, 10:23 AM
E
My outdoor faucet continues to run even what shut off. From my review of online information, the problem probably is the washer. I began disassembling the faucet. When I went to loosen the white plastic tube in order to gain access to the washer, the tube crumbled, as seen in the attached picture. I believe I need to loosen and remove the white plastic tube to gain access to the washer. Is there any way I can do this, being that I can't grasp onto any part of the white tube? Thank you very much. -- Eric
Attachment 37797Attachment 37798
Old 09-06-14, 11:24 AM
czizzi's Avatar
Received 10 Votes on 8 Posts
http://www.doityourself.com/forum/el...-pictures.html
Try again with your attachment following the above link to instructions.
Old 09-06-14, 01:14 PM
E
Original Poster Here. This is the picture, I hope:
Old 09-06-14, 01:17 PM
Received 851 Votes on 797 Posts
Is that one of those frost free valves ?
Old 09-06-14, 03:16 PM
P
Received 495 Votes on 455 Posts
It looks like new sillcokc time. The packing nut appears broken and what a P.O.S. if it was made of plastic. I've never seen that before. You might get amazingly lucky and find another to be able to exchange parts but I think replacing the whole thing is easiest at this point. Is there a crawl space or unfinished basement behind the wall or is it finished space?
Old 09-06-14, 03:45 PM
E
The other side of the wall is unfinished basement -- the pipe is very accessible
HTML code is On
