Another what are these stub-outs thread....?
Old 09-06-14, 01:43 PM
I've looked at a ton of these...they are all the same but different. So, guesses here? The toilet seems obvious as it's 3". Next, I have a 2' over alone against the wall - shower, right? Finally, there's a wood framed box built around1 1/2" pipe that's lying horizontally in the ground - it's capped, but clearly looks like it attaches to the 1 1/2" pipe that rises right next to it. Would that be a vent or for a sink...or shower? The framed box seems like it would be for a tub or shower but 1 1/2" seems small. Or does it?
The big pipe in the background collects from numerous points upstairs. Would I need to leave that accessible as it looks like it has a place for a cleanout near the bottom?
Old 09-06-14, 02:05 PM
https://drive.google.com/file/d/0B3C...it?usp=sharing
Old 09-06-14, 02:08 PM
Old 09-06-14, 08:41 PM
F
Received 34 Votes on 26 Posts
The box in the floor is for a bathtub trap. Bathtubs use a 1-1/2 inch drain whereas a shower requires a 2 inch drain. The vertical stub next to the box is most likely the vent. The rest I can't comment on. Look in the ceiling for a capped pipe, either 1-1/2 or 2 inch for the vent connection.
HTML code is On
