1.5 OD hole saw size?
Old 09-06-14, 04:06 PM
FOr a 1.5" pvc pipe, what size hole saw should one use to cut a hole to extend pipe thru basement wall to ouside? 2 or 2 1/8?
Old 09-06-14, 04:22 PM
Handyone's Avatar
You don't want it too snug, it won't give any play area. I would go 2-1/4" (or 2-1/2").
That gives you a little wiggling room. If you're concerned about air, seal it after pipe is in.
What you don't want is to drill too small and then have to ream it out, because re-drilling with another hole saw isn't going to happen.
Old 09-06-14, 05:14 PM
Received 851 Votes on 797 Posts
2-1/2" is a little large..... go with 2-1/8" or 2-1/4".
Old 09-06-14, 05:52 PM
Handyone's Avatar
Yes,
PJ's right. If you want any slope, plan ahead. It's hard to get the core out of a hole saw after drilling at an angle, but it can be done. Use a good scratch awl.
Old 09-06-14, 06:38 PM
chandler's Avatar
Received 4 Votes on 4 Posts
If going between floors, you will seal the hole with firestop anyway, so 2 1/8 or larger will be fine.
Old 09-06-14, 07:07 PM
Z
Received 10 Votes on 10 Posts
If thatís a masonry wall isnít sleeving through the wall a requirement?
HTML code is On
