hot water faucet on the bath tub
I have an older home and when I turn on the hot water faucet in the bath tub the water leaks around the handle of the faucet. I do not know the make or model of the faucet. Could this be a washer problem or what?
If it leaks only when you turn the water on, it's probably just a worn rubber o-ring on the valve stem assembly.
If you need to know how to D-I-Y, just ask.
Good Luck!
Good Luck!
