Question on what shut off to get
Old 09-17-14, 01:40 PM
I have town water and I have one old shut off be fore my water meter in my basement, it looks to be a check or a gate valve. I'm not shore. Then somebody put in a newer shut off after the meter both shut offs do not turn 100% off. So I'm looking at replacing the one newer one with what type of valve is the best to get? a ball valve? It's 3/4" copper with sweated valves. and the psi throw them is around 100. after the valves I have a reducer to drop it to 60 psi.
On a side note, can a pressure reducer go bad and what are the signs?
Old 09-17-14, 01:50 PM
lawrosa's Avatar
Super Moderator
Received 55 Votes on 48 Posts
Yes a ball valve.. Make sure the installer does not overheat when soldering.. Also the water will need to be shut off at the street to change the one before the meter...
Use a WOG..
IMO go to your local plumbing supply and get a watts valve..
[ATTACH=CONFIG]38444[/ATTACH]
Old 09-17-14, 08:01 PM
Pressure reducers can go bad.
Simple enough to check the pressure.
Watts 3/4 in. Plastic Water Pressure Test Gauge-DP IWTG at The Home Depot
When it does go bad you can expect plumbing leaks, water hammer, toilet flush valve messing up.
HTML code is On
