HW radiator PEX piping
Old 09-22-14, 02:52 AM
A
I've read about PEX piping for all plumbing and the plumbers used this for our new material. I'm moving an old cast iron radiator and wondered if there is a PEX pipe approved for boiler water in this application. I'm in St. Paul MN, the house is a 1907, the radiator is only going from one side of a hall to the other and there is a circulating pump on the newer boiler. I'd prefer to use new threaded pipe for aesthetics but my experience with that is limited and don't know if I can arrange lengths accurately enough to make things fit. Is PEX OK for hot water radiators?
Old 09-22-14, 05:43 AM
lawrosa's Avatar
Super Moderator
Received 55 Votes on 48 Posts
Yes but you need pex specifically for hydronic heating...This type of tubing has an oxygen barrier.
See link below...
PEX Tubing , PEX Pipe for Radiant - SupplyHouse.com
HTML code is On
