Plumbing removal
Old 09-24-14, 02:26 PM
Plumbing removal
Hey all - this is my first post here. First time home owner, purchased first house about 18 months ago.
We have an outbuilding that is fully plumbed (has a shower, toilet, and sink). The water is all shut off to the building, but the plumbing is all still in tact. We want to remove all the fixtures and effectively remove the plumbing, but keep the lines underneath in case the next owners want to utilize the plumbing.
My question is this - after removing the toilet, sink, etc... how exactly do I "plug it up" for lack of a better term? I basically want to terminate all of the plumbing lines at the floor (or under the floor), but i'm not sure how to go about doing that. Are there fittings that I can buy to just cap all of the lines (including the sewage line under the toilet)? And could temperate swings possible do damage to my septic system with empty lines leading from the toilet to the septic?
I apologize if these answers are already on the board somewhere - I probably didn't use the correct terminology in my searches (again, very newb here).
Thanks for any and all advice and hope to see you guys around the forum!
Old 09-24-14, 02:51 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
You can use test plugs to seal the drains.
Image Source: True Value
Old 09-24-14, 04:10 PM
P
Received 478 Votes on 439 Posts
You didn't say what the pipes are made of but if they are PVC or ABS there are glue in test caps. They are less expensive than the removable type Ray2047 shows and are lower profile so they are easier to bury or cover over in a wall or floor. If the plumbing needs to be used in the future they are designed for the center to easily be knocked-out. A big benefit of the type Ray shows is that it can be used on any pipe material as long as you buy the correct size but I don't know their status as far as being permitted for more than temporary use.
Old 09-25-14, 12:59 PM
Thanks Pilot and Ray! All the piping is PVC. I think I've got enough to go on. Thanks again!
HTML code is On
