black colored plumbers putty?
Old 10-13-14, 05:10 PM
D
I have putty outside my house that looks like plumbers putty, and it is colored black. This was used for the pipes sticking out of my house, to seal around the pipe and siding. Where can I find this black colored putty?
Thanks,
Old 10-13-14, 05:15 PM
Norm201's Avatar
Received 678 Upvotes on 601 Posts
Most stores should carry it. The stuff in my store is gray. That's the most common color.
Gunguy45's Avatar
Super Moderator
Received 5 Upvotes on 5 Posts
It may be black now, but I think most of them are greenish grey? Should be in the electrical aisle and possibly in the piping aisle
SEAL CONDUIT 1 LB BAR
Old 10-15-14, 06:41 AM
Z
Received 372 Upvotes on 332 Posts
For sealing around the pipes to the siding, I would use silicon caulk. It comes in a few different colors (white, almond, gray, black, etc) and does a great job keeping the weather and critters out.
I would only use plumbers putty for actual plumbing connections.
Old 10-15-14, 06:45 AM
Received 759 Upvotes on 664 Posts
IF the siding is painted - don't use pure silicone caulk as it doesn't accept paint!
Annonee Moosee voted this post useful.
Old 10-15-14, 09:19 AM
Gunguy45's Avatar
Super Moderator
All depends on the size of the hole. Very few penetrations through siding are tight enough to just caulk. Control wires or a cable TV connection maybe, but most AC lines, water lines etc have quite a large gap.
