How can I re thread a pipe
Old 10-30-14, 09:09 AM
I have a metal pipe inside wall on my shower (it is the pipe that the shower tap threads into) and it is stripped.Can I re thread and if so how?
Old 10-30-14, 09:15 AM
ray2047's Avatar
Received 13 Votes on 11 Posts
Do you mean the pipe from the faucet to the shower arm? Probably not. Best to replace it.
Old 10-30-14, 09:16 AM
P
Received 522 Votes on 479 Posts
It probably cannot be re-tapped. That fitting is 90 degrees so a pipe tap would likely bottom out on the back of the fitting before it could go deep enough to cut new treads. If you can borrow a tap I would give it a try but I don't think the chance is good enough to go buy a tap.
Old 10-30-14, 04:03 PM
Really want to take the chance of a leaking hidden fitting behind a wall?
Replace it.
Old 11-01-14, 07:16 PM
W
Replace what is bad . That stuff is not that expensive .
God bless
Wyr
HTML code is On
