New Garbage disposal humming, not jammed
Old 12-08-14, 09:15 AM
K
The old one stopped 2 weeks ago, it was humming and since it was more than 10 years old I thought to replace it with a new one.
Plumber bought badger 500 1/2 hp and installed it 2 weeks ago where it worked fine. Last night, it stopped, same problem as old one (humming and burning smell, but not jammed), so I used the wrench to twist it and went throw without any problem. I checked the power outlet using a reader and it read 120V. (when turn on the switch)
also, cleaned the disposal and didn't find any hard object or anything.
I thought someone has an input before I return it.
Thanks.
Old 12-08-14, 09:56 AM
Handyone's Avatar
It is very rare that a new ISE Badger 5 would not work.
I would wait for more responses. It's possible one of the Mods may move this to electrical.
A humming indicates to me the motor is jammed, but you said motor spins using hex wrench provided with unit?
Also: ISE has an in-home warranty, you do not need to remove unit, they will come to you if you suspect a bad unit.
HTML code is On
