Submerged pump got stuck while being installed
Old 02-01-15, 10:09 PM
I have installed the submerge pump the ground well .once it cross 100ft bore well pipe size reduce to 3inch and gape between submerged pump and bore well just 0.5 inch difference due to rock chips it got stucked in between , we tried chain pulley by ropes due strong stuck in between even rope and wire got cut . the only option I have is pipe which is connected pump so kindly say your suggestion to get back the pump.
MODEL: TEXMO 1.5HP SUBMERGED PUMP
Bore size min. 3”and above
Power Range 0.5 to 1.5 HP
Voltage Range 220V- 240V, AC Single phase , 50Hz
Speed 2900RPM
Motor Type Wet Type water filled water cooled Induction motor
Coupling Key / NEMA
Head Maximum 83 M
Discharge Maximum 5500 LPH
Liquid temperature Maximum 33ºC
Operating Pressure Maximum 20 bar
Sand content in water Maximum 50 PPM
Old 02-02-15, 12:07 AM
Received 482 Votes on 452 Posts
Welcome to the forums.
You are telling us that you were installing a 2-1/2" pump in a 3" casing and it got stuck due to falling rock chips. In trying to remove it.... the discharge pipe broke and the power wire got cut.
Is this correct ?
HTML code is On
