leak from air gap
Old 03-28-01, 07:06 PM
Guest
Question
Water spews from the air gap whenever dishwasher drains. Replaced air gap but still have same problem. Also checked for obstructions in outlet hose off garbage disposal. Any suggestions before we call in a plumber? Thanks!
Old 03-29-01, 06:21 PM
Guest
There has to be a stop up in the line that is forcing the water up the air gap. Check it closer and I believe you will find it to be true. One thing you could do is take it apart get a bucket and pump some water out to see how it works.
Good Luck
John
HTML code is On
