loosening fittings (hard water)
Old 05-08-15, 04:27 AM
D
Have a customer that has two showers both affected by hard water deposits; I told him to remove the heads and soak them in vinegar for a few days, do them one at a time but.....he has tried to remove the head from the shower arm and is afraid of damaging the finish or maybe splitting the head. Is there something we could spray or brush on the hard water area of the fitting (like you would on a badly rusted fitting) that might soak in and allow it to break loose? Then we can clean up the shower arm, use Teflon tape to help retard further formation and hopefully get the head and fittings cleaned up good.
I am sure one of you great plumbers have bumped into this issue over the years!
Old 05-08-15, 04:54 AM
P
Received 1,844 Upvotes on 1,651 Posts
You could try a acid like white vinegar or mineral remover like CLR. At best I think it would be a very slow process required frequent, regular applications to keep the area wet and dissolve the minerals. It might be easier and quicker to replace the shower neck and head.
Old 05-08-15, 06:00 AM
W
Received 60 Upvotes on 52 Posts
Wrench
Would this work to loosen fittings without damaging?
http://www.amazon.com/WorkShop-85861...strap+wrenches
Old 05-09-15, 05:05 PM
W
Received 13 Upvotes on 11 Posts
Hi,
I read this somewhere it sound like it could do the job. Without removing the shower head take a plastic bag fill it with vinegar and tape it on the shower head and let it soak.
Good Luck Woodbutcher
