Tankless Hot Water Heater
Old 03-30-01, 07:27 PM
Guest
Unhappy
I'm looking at purchasing a water type of softner and a tankless water heater. I've been doing some research on the two items but mostly have only run across the manfacturers. I've even called a few only to get the normal sales pitch. What exactly should I be looking for in both the water softner and the tankless water heater?
I thought I remembered something about an electronic softner of some type I'm not interested in chemicals or salt.
I want something that will handle your average home and can work during peak times.
Thanks for the help.
Old 03-30-01, 07:50 PM
N
Most of the reply's I've seen here will tell you there is not much support if your tankless heater breaks down.
Old 03-31-01, 09:34 AM
Guest
Angry Tankless or Thankless?
I'm putting together a list of tankless hot water heater mfg. I hope to be able to share it with others. I'd like to get one without too much money or trouble.
What about water softners?
HTML code is On
