Is it normal to have a gap in the faucet with water pressure
Old 06-02-15, 02:07 PM
Q
Received 1 Upvote on 1 Post
Hello all,
I have seen little water leak through the center gap with my Delta faucet and I am not able to find the model number. The only part shown on the tip of the faucet is as follows:
Delta 2.2 GPM 8.3 L/min A112 18.1
I have replaced two rubber O-Ring inside the faucet. One strange thing is that when I turn on the water handle, the gap is expanded a little. Is this normal case with Delta faucet? If not, which part I should replace?
Originally, it doesn't leak water if I turn off the handle.
Question 1> Is this gap normal?
Question 2> How can I find the model number for this Delta faucet?
Thank you
Old 06-02-15, 04:18 PM
P
Temporarily Suspended
In those situations, I contact the company & email them a pic of the faucet. They will know right away what model it is. They will probably also send whatever parts are needed to correct the problem, for free. I've done it with Moen & Danze.
Old 06-03-15, 06:52 AM
Q
Thank you for your great helps!
Old 06-03-15, 07:47 AM
P
You're welcome
