Bathtub Faucet Seat Stuck
Old 03-31-01, 12:34 PM
Guest
The seat on my BAthtub hot water faucet is stuck and When I used a seat tool it rounded off inside. Any suggestions?
Old 04-01-01, 05:23 AM
Mike Swearingen's Avatar
Cool
Dave,
You need to spritz the seat threads with WD-40 and let soak to loosen corrosion.
Then get a small "easy-out", tap it gently, but snuggly, into the seat hole (do NOT damage the threads of the wall fitting), and turn it out counter-clockwise.
"easy-out" (comes in different sizes...pick one that will fit into your seat)
Wrap 1-2 flat turns of teflon tape clockwise only on threads of new seat, and install it snuggly. Don't over-tighten.
Good Luck!
Mike
Old 04-01-01, 10:00 PM
Guest
Thank You
Thank You, Thank You, Thank You.
