Shower Valve Identification
Hello, I need help in identifying this valve. No idea what brand it is. I tried using the pfister universal kit but it didn't like it. Below is the picture:
http://i296.photobucket.com/albums/m...psija26bhy.jpg
welcome to the forums.
I would need to see the cartridge out to tell what it is..
But IMO you have enough room to replace that with a moen moentrol and goof plate.. That divertor has no pressure balance spool and is not up to code...
But it looks like an old avante divertor...
Pfister S742920 Avanti Cartridge - Faucet Cartridges - Amazon.com
Call some plumbers in the area and get a some estimates...
Since the hole is open already, and no tile needs to be cut, it should be minimal. Cost of valve a two hours labor.
In NJ I would say $600 more or less..
Priced vary by location...
I recommend this moentrol. You can buy yourself and ask the plumber to install. Or ask if he can get it. Usually if plumber supplied they will warranty it..
http://www.amazon.com/Moen-3520-Moen...words=moentrol
[ATTACH=CONFIG]53012[/ATTACH]
You also need this remodel plate...
http://www.amazon.com/Moen-1920-Remo...=remodel+plate
[ATTACH=CONFIG]53013[/ATTACH]
