mini tubing cutters - close quarter cuts
I have 2- 3/4" pipes that run horizontal to each other within 2" apart approx.
Whats the typical radius needed to rotate mini tubing cutters around a 3/4" pipe?
Can I make this cut? If not, whats the easiest method.... I hesitate to use a sawzall as I don't want to disrupt piping in the vicinity.
Or use these lennox close quarter cutters. They work so well, I use them for all my pipe cutting, and they only need about an inch clearance.
Lenox Tubing Cutter Set, Copper, Manual 14833TSK | Zoro.com
I have the basic small and an extra small pipe cutters (I think 3/4 pipe would be a max for the extra small) and either one would work with 2" between the pipes. Slow, but inexpensive.
Bud
Bud
