new shower drain question
Old 08-25-15, 10:16 AM
V
Received 1 Upvote on 1 Post
hello, I am replacing a tiled shower with one of those fiberglass type kits. The old drain is imbedded in grout/mortar and attached to cast iron piping. house was built in 50's. so what's my easiest/best way to hook this new shower drain up? The cast iron looks good, but after the trap where it goes into the fitting right above the trunk line, it just lifted out, and it doesn't seem to have been sealed at that junction. Is that normal?
When I pour water down the old drain it doesn't leak there, but that's questionable, at least to me, just a regular person who enjoys diy.
So i guess there's two questions here. Many thanks for considering my post !
Old 08-25-15, 11:25 AM
lawrosa's Avatar
Super Moderator
Received 79 Upvotes on 71 Posts
If it is/was a leaded joint you have issues to fix and it may not be easy..
But I would need to see a pic of what your talking about...
Old 08-25-15, 05:15 PM
V
thanks, will get some pics tomorrow hopefully.
Old 08-26-15, 10:55 AM
V
here's pix. Name:  IMG_0291.jpg
Size:  33.7 KBName:  IMG_0292.jpg
Size:  41.7 KBName:  IMG_0293.jpg
it just lifted right out of that coupling on to of the bottom line
Old 08-26-15, 12:09 PM
lawrosa's Avatar
Super Moderator
Cant see where it goes into. Is that a rubber banded coupling?
I would probably convert to PVC at certain points..
Old 08-26-15, 12:53 PM
V
in the second pic, that coupling is on the ground, basically, and goes into the septic line, I don't see any rubber or evidence of rubber, it could be all gone. the whole pipe just lifted right out of that coupling with little effort.
how would I connect new pvc to that coupling in the second pic and not have a leak? thanks a lot too
Old 08-26-15, 12:55 PM
lawrosa's Avatar
Super Moderator
I need a few close up shots of that tee with the so called coupling...
Old 08-26-15, 12:58 PM
lawrosa's Avatar
Super Moderator
Another issue, there is no vent for that shower drain... Whats that stack look like on the right of the pic?
Also are walls open that you can get a vent to the attic?
If that shower is in a bathroom where are the other fixtures pipes?
Do it right know IMO or youll just be hacking it up with that old piping..
Old 08-26-15, 03:08 PM
V
I will take some better close-up pictures tomorrow. This bath is a 4 x 8 bathroom with a sink, toilet, and the shower, and one vent services all three. It's right in the middle of the room, I'll try to get a picture so you could see it. Thanks again
