PVC drain repair question (elbows)
Received 0 Votes
I'm trying to repair the drain under a sink and shower. It's leaking right where several elbows and Ys come together, so simply cutting pieces out and replacing them doesn't look possible without cutting everything back to straight pipe and replacing all those elbows and Ys. There must be an easier and more clever way. (Leak outlined in green). Is cutting between the elbow and Y, and then inserting a Fernco acceptable?
Dont think it will work as you will need to put the no hub coupling over the hub.. Once you cut theres no going back...
How bad is the leak?
I would just prime all around the joint in the green outlined area then glue all around it. Let it dry some and dont use water for a few hours..
Dab the glue around joint heavy like....
No offense bit it looks like a work in progress as the tub part is still disconnected from the pic..
And nothing looks glued together..
So do you really have a leak?
Maybe this is a joke? That line comes from the back wall comes up and into that Y to go back in the drain???
Looks like something hokeys going on...
[ATTACH=CONFIG]55318[/ATTACH]
