Moen Diverter Valve Problem
Old 08-29-15, 01:28 PM
W
Received 51 Votes on 46 Posts
Moen 8300 series tub and shower 3-stem valve
I replaced the diverter shown below:
The original problem was that when using the shower, some water bypassed the shower and came out through the tub spout. The problem still exists with the new diverter valve stem. What do i need to do to correct this problem?
Old 08-29-15, 04:20 PM
P
Temporarily Suspended
Did you replace it with a Moen part? If not, Moen will probably send one to you for free.
Old 08-29-15, 04:44 PM
W
Part
The replacement is a Moen part.
Is there supposed to be a washer or ring between the two mixing holes and the output hole?
Old 08-29-15, 05:33 PM
P
If it's a Moen part, it should work. There could be a problem with the shower body, itself. However, if it's only a slight drip, I wouldn't worry about it. Otherwise, wait for Lawrosa to comment. He & his cow know more than I do.
Old 08-29-15, 06:05 PM
lawrosa's Avatar
Super Moderator
Received 77 Votes on 69 Posts
Hate to say this but in 30 years on the east coast plumbing I have never ever seen one of those...
Ill look around for info
Old 08-30-15, 11:47 AM
W
Model Number
My apologies, guys. The model number series is 83000, not 8300.
Here is the parts diagram:
Old 10-18-16, 11:29 AM
D
At the end of the diverter valve stem n where it was into the pipe a washer fits at the whole end covering the holes kinda like a thimble with two holes on the side one for shower one for tub so when you turn it it will divert the water to where you want it. I had mine fixed recently. Also the shop where it was bought is no longer there n my ex years ago had bought extra. I have no idea what it's called I do however would like to order more. so I'm on my search for more good luck
