backed up sewer
Old 04-07-01, 05:22 AM
Guest
Unhappy
It rained the basement flooded.Now the tubs and showers
are full of sewage. I got professional strength sewer cleaner from the hardware store .Nothing is working. Toilets flush but when I flush there is water leaking in the basement. Please HELP!!!
Old 04-07-01, 06:19 AM
Mike Swearingen's Avatar
Cool
Your description is not too clear.
When you flush your toilets, it comes out in the basement?
Did the rain cause the basement flooding?
Has it ever flooded from rain before?
Do you have a sump pump in the basement?
Can you see a broken drain line in the basement?
Where is it leaking in the basement?
Are you on public sewer? If so, have you called them to check the main line?
Do your neighbors have a problem?
Have you tried snaking the main drain line from the clean-out plugs?
Give us some more info.
HTML code is On
