ABS Water Closet Flange Question
Received 0 Votes
Hi,
We're renovating a 70s-built bathroom and have removed the tub, toilet, wall tiles and tile (mud job) floor.
Since the toilet flange was not in good shape it came out as well. The drain pipes in our house are 3 inch ABS, so I'd like to simply get a new ABS flange and glue it into the existing pipe fitting.
This fitting looks like it will take a 3.5 inch OD flange. The top of this fitting is about 1.5 inches below the top of the existing plywood floor, so the new flange is going to have to be long enough to extend over the new floor. Once the new floor (tiles over Durock) is in, we can cut the stem the of the flange to get it flush with the tile.
So here's the question: Where can I get a 3 inch ABS flange that will be tall enough to get over the new floor?
Changing the pipe fitting to PVC to accommodate a PVC flange is not out of the question but I'd like to see if we can simply get a an ABS replacement first.
Thanks
Thanks
Why wouldn't you just glue in a piece of 3" abs to existing closet el long enough to extend above the finished floor. When floors in, cut the pipe flush and drop on a standard 3" ABS closet flange.
If the hub of the closet el has the remains of the old pipe/flange in it, you can remove with a PVC fitting saver tool. Or cut out the el and some of the drain pipe and put in all new.
If you switch to PVC, many codes require using a fernco coupling as they don't allow gluing PVC to ABS.
Received 0 Votes
Thanks Carbide
Thanks for the advice Carbide, it sounds like it should work as long as I can make a good connection inside the elbow. The inside of the elbow's hub is in pretty good shape. I used a heat gun to get the old flange soft and then wedged a screw driver between it and the elbow. Residue was removed with a round sanding bit on a drill.
Finding ABS in my neck of the woods is not so easy. I'll make some calls to some plumbing specialty stores today. If I can get what I need, I'll try your first suggestion.
Maybe we won't be cutting out plywood after all.
Thanks again.
Thanks again.
Received 0 Votes
Thanks Ray
Called around this AM and found that no one carries ABS in stock. The only way I can get what I need would be to order a 20 ft. pipe--and that's about 19 more feet than I need.
At Ray's suggestion, I called the mobile home center that's about 3 miles away and they said they had lots of ABS--pipes and fittings. Gonna swing by tomorrow.
Don't re use that ell.. your asking for trouble IMO...
Get new fittings...
The home store should have all you need...
here...
Search Results for abs flange at The Home Depot
and here...
ABS DWV Pipe & Fittings - Pipes & Fittings - The Home Depot
Received 0 Votes
OK, I followed Ray's suggestion and picked up a piece of 3 inch ABS pipe from the RV store.
Dry fitted it into the existing Wye fitting and it goes in with no problem. It fits fairly snuggly, but it's not as tight as if you were to put a new fitting onto a new pipe. At the top of the fitting there is a small gap between the outside surface of the pipe and the inside surface of fitting. This gap is only on one side and is no bigger than about 1/16 of an inch.
The connection becomes tighter further into the fitting. You can spin the pipe inside the fitting with your hands but it takes some effort.
Any issues here? I'm hoping the glue will fill in and make everything water tight.
thanks
thanks
It's not really glue. It is solvent cement and melts the pipe together.
So, if you want the solvent-cement to be a bit thicker just stir in some filings from a piece of plastic. This thicker bodied cement will fill any voids.
