more on kitchen sink
is it possible to come though the basement clean out up to the back of the kitchen sink to try to remove a clog i am unable to get thougt the cast iron pipe from the front, by the way the trap set is clear i have a 25 foot store brought snake that hand turns.
Received 1 Upvote
1 Post
You can't remove the trap and feed the snake down?
You may need to get a more flexible snake.
The clog needs to be snaked from the smaller drain pipe out, not from the larger drain pipe back.
Good Luck!
Mike
Good Luck!
Mike
