toilets
Old 04-10-01, 04:45 PM
Guest
Question
I woke up one morning to find the toilet bowl dry.
after flushing to fill the bowl again I noticed the water seeming draining out of the bowl.
There was no aparent leak as the area around the bowl is dry.
Thinking that their was a crack or something like that around the p-trap I began to remove the toilet to replace it.
After removing the tank and naturally some water draining into the bowl I now observe that the bowl is holding water.
WHAT COULD POSSIBLY EXPLAIN THIS!
any thoughts????
kaknbru
Old 04-10-01, 06:25 PM
Mike Swearingen's Avatar
Cool
Sounds like you have the same problem as Byron on the "Toilet water Level" thread in here today.
See it for the solution.
Good luck!
Mike
HTML code is On
