Leaking water service valve/plumbing
Old 01-30-16, 02:16 PM
D
Separated from http://www.doityourself.com/forum/pl...sion-pipe.html
Please help. Not sure what to do. Called a plumber and he wouldn't touch it. Said anything north of the top valve is the city's problem. So I called 311 last night been waiting over 15 hours. Called DEP this morning and they have my ticket. Commented that someone would be here by 3pm. Called back 311 and they tell me to call 911?!?
Any advice?
Thanks in advance,
David
Old 01-30-16, 02:20 PM
Received 1,197 Upvotes on 1,152 Posts
Welcome to the forums, David. I moved your post into its own thread to increase visibility. Can you explain what's actually happening?
Old 01-30-16, 02:22 PM
lawrosa's Avatar
Super Moderator
Received 79 Upvotes on 71 Posts
Post some pics .. I got your PM..
We will help you more after you reply back...
If its the towns issue they will fix it.. Just need to wait for them to respond...
Old 01-30-16, 02:27 PM
D
Thank you so much Stick. Is there a way where I can post a video or picture?
Basically, there is a small leak right about my main water line in my basement. It's right above the two levers. I see some corrosion surrounding the area. Is this my responsibility or NYC? This plumber I called wouldn't touch it and now I'm just waiting. I have a large bucket catching the water now.
Old 01-30-16, 02:29 PM
lawrosa's Avatar
Super Moderator
Call another plumber... Maybe needs to be turnd off at street to fix and why the plumbers will not fix it...
I am sure the water department will repair when they come out...
Old 01-30-16, 02:51 PM
D
I couldn't load the video. There is water leaking from about the white area.
Thanks,
David
Received 3,478 Upvotes on 3,123 Posts
I was under the impression it was a geyser. Is it just a trickle ??
Old 01-30-16, 02:58 PM
D
Started as a trickle but now it's starting to come down a little faster. I have a bucket catching the water. I dump the water every 2 hours now
Old 01-30-16, 03:01 PM
D
This is probably the best pic.
Old 01-30-16, 03:05 PM
Can't quite tell from the pictures but it looks like the leak is in your side of the meter. It looks like the city line comes in at the bottom.
Old 01-30-16, 03:09 PM
D
City line comes from the top
Old 01-30-16, 03:17 PM
D
Called another plumber. Any idea what a rough estimate would be?
Old 01-30-16, 03:34 PM
Handyone's Avatar
No real way to give an estimate. Everything looks to be in good shape except that upper pipe.
I'd be happy if I could get out with a $200 - 300 bill. We'll see.
Old 01-30-16, 05:26 PM
D
Problem fixed replaced gasket and tightening of some screws 200. Great guy who came out! Spent about 1 hour to get it right.
Thanks all!
