plumbing - copper pipe soldering
Old 02-03-16, 05:07 PM
N
Wink plumbing - copper pipe soldering
I have to replace a copper fitting from a male fitting to a female fitting on a 1 inch line. The main water isolation valve is 3 inches away. Is it possible to get the fitting hot enough to pull off and replace it with a new fitting?
Old 02-03-16, 05:12 PM
Received 125 Upvotes on 110 Posts
Picture would be nice.
Why not just use a brass pipe coupling?
Old 02-04-16, 04:58 AM
Norm201's Avatar
Received 677 Upvotes on 600 Posts
It should be possible. Use MAPP gas instated of propane. You might want to wrap a wet rag around the valve to keep it cool and not get loose from the heat.
