New waterline for barn supply
Old 02-09-16, 06:44 AM
O
I ran and hooked up (barn side) a frost free in the barn this summer. In ground is 1" 160 PSI poly. It's already through the basement wall and sealed, so I just need to do the in basement hookup. That being said, I'm looking at hooking into and putting a shut off from my existing supply. Question is, I'm not finding a connection for 1" poly to 3/4" pex. Maybe I'm looking in the wrong area.
Is there something in an "L" vs. a straight male/male, or is this a bad idea as far as restricting flow? I'd like it to stay tight up against the wall like an LB if possible.
Heres a pic of the current pressure tank that feeds into a water system. I'm probably going to clean it up a bit while I'm at it. Thanks
20150409_114910
Old 02-09-16, 07:57 AM
P
Received 1,849 Upvotes on 1,655 Posts
Your photo shows copper piping so I'm confused why you're asking about a PEX fitting? You will have to assemble the fitting necessary to make the transition. I don't know of a 3/4" PEX to 1" barb so you'll have to us a coupling and reduction to join a PEX on one end and a barb fitting on the other.
Old 02-09-16, 09:18 AM
O
I'm going to tap into the copper for my supply, then it will be PEX over to the other side of my basement where the 1" poly is.
Old 02-12-16, 10:33 AM
Z
Received 372 Upvotes on 332 Posts
In case you haven't completed this yet, it's an easy transition if you use a 3/4" PEX -> 3/4" threaded, then connect that to a 3/4" threaded -> 1" barb connection. Add some teflon tape and/or pipe dope to make the connection and you have your very own PEX-to-PE fitting.
