Leaky pipe/nut
Leaky pipe/nut
Hello first time here on these boards and I was wondering I just replace a faucet and stainless supply lines under my sink. And I didn't have anything to seal the nut when I reinstalled them to the supply line and faucet. So now I have a small drip from both the hot and cold line. My question was instead of taking them both off which they were a pain to get on. Can I just use some type of epoxy putty around the top and bottom of the bolts for a quick fix? I really don't want to mess with this anymore since I worked on it for 5 hours yesterday.
Welcome to the forums!
Unfortunately, a quick fix will likely be neither quick nor a fix.
Are these flexible hose type connectors? If so, they may just be over tightened. The flex connectors should be tightened hand tight, then one more turn. You should not need to use any kind of sealer on them.
If they are not flex connectors, this would be a good time to change to them.
They are not flex hose they are straight stainless steel going from the pipe from the floor up to the connector on the back of the faucet - See more at: http://www.doityourself.com/forum/pl....Jocxtagb.dpuf
I tried uploading a picture it just wouldn't let me - See more at: http://www.doityourself.com/forum/pl....Jocxtagb.dpuf
This is what I have going on right now, see the bottom where its connected has a crazy three part grey fitting that comes apart. I have a friend who is a apprenticeship for a union and he said he has never seen something like that
Received 38 Upvotes
Using the flexible connectors that Ray shows is a much better, and far, far easier, method of connection. Since the flexible connectors have rubber seals in the nuts no additional pipe sealant is required or even desired.
That gray fitting and pipe in a stick built house normally wouldn't be there, You would have a valve on the wall. If you do not already have a valve I would add a ½" pipe thread by 3/8" compression or flare valve to the top of the pipe. Flex lines that are 3/8 compression or 3/8 flare on one end to fit a valve and ½" pipe thread to fit your faucets on the other end are common. Just be sure if you get a flare valve get a flare flex line. 3/8 flare and 3/8 compression or different.
Be very careful if that gray pipe is polybutylene pipe. It breaks easily. http://www.sterlinginspections.com/Polybutylene.html
Yes looks like old quest piping.. ( grey stuff)
As ray stated....
Remove both supply's and get 5/8 x 3/8 braided supply lines.. 18" should do fine. Careful to not turn out the 1/2 x 3/8 adapter threaded into the grey fitting.
[ATTACH=CONFIG]62737[/ATTACH]
As ray stated....
Yea its polybutylene thats one reason why I was a little nervous jumping into this project. So what you are saying is that i could add a valve right above where the water shut off knob is for both hot and cold? and then would beable to connect a flex connector to it to just wipe out the whole copper pipe i have in its place right now?
Unscrew the nut on the metal supply line here.. It should be 3/8.. The new braided line should screw right onto the threads that remain...
[ATTACH=CONFIG]62742[/ATTACH]
Then unscrew these. this is 5/8 and the other end of the braided line goes here..
[ATTACH=CONFIG]62743[/ATTACH]
Ok so that grey fitting is three seperate pieces you have to disconnect basically the bottom piece to pull the supply line out. The bottom part stays on and you pull the line out. I only say this because If I unscrew the top part the line is still there
#22
The line doesn't pull out because inside is a little piece that slides in with a metal ring. Basically keeping the line in place where u fit it to be to match up with the faucet. You have to disconnect the bottom to pull the whole thing out
#26
I'm gonna try to take it apart and put some seal tape and see if that works
#29
But often on old supply the cone is part of the supply... Which I think you have..
With those, removing the nut and pipe, doping the cone may help.
In reality I guess its a flare type fitting for clarity...
[ATTACH=CONFIG]62758[/ATTACH]
#35
Only problem I ran into with keeping it straight is since both lines are shorter then my old faucet I had to push the line over some on the hot line. If u can see in the picture below. It seem to screw on straight but it is somewhat bent I suppose
