Water pipe heat cable for pex
Old 02-20-16, 07:37 PM
I had a frozen pipe which is used for heating. Pipe was routed outside and goes up to 2nd floor. Froze pipe was copper and that section was switched with a PEX pipe. I wanted to know if i can use the heating cable with copper and PEX mix.
I have two shark bites on two ends with copper on one side and pex in the middle.
Old 03-02-16, 07:15 AM
Received 125 Upvotes on 110 Posts
Need to relocate that pipe inside the home some how.
Just makes no since in your area to have ran it that way.
Old 03-02-16, 03:22 PM
F
Yes, you may use the heat tape with the PEX tubing although as the others have stated it would be better to re-route the piping.
