Life of sewage pipes under house?
My house (in Los Angeles) was built in the mid-50's. House has a concrete slab foundation. The exterior clay sewage pipes have all been replaced with ABS. I assume that there would be iron pipes under the house? How long can these pipes be expected to last before they start to corrode and have holes?
Temporarily Suspended
You said that you "assumed" that they were cast iron. I don't know what they used in LA. in the 50s. Here in NY, that's exactly what they used & way before the 50s. They certainly lasted a long time.
75 to 100 years according to this site. Pipes And Plumbing Lifespan | How Long Do Pipes Last | HouseLogic
Drain Pipes
I had cast iron pipes under a concrete basement floor. The pipes lasted 25 years before they started leaking. (House was built in 1967).
No basement in my place. How would I know if they are leaking? Roots growing into them and causing a backup?
A camera inspection is the only way. In my area this would run approximately $300 -350.
Personally I would pay for the camera inspection. The old cast iron could be in the worse shape or actually shiny inside, it's a gamble and if it is in good shape you will never work on it except for tees and other fittings that are above grade.
There's no danger in waiting. If pipes are flowing well and it's rare you have a backup, I wouldn't do anything. If your showers are draining well, that's even more reason to not be concerned.
Pipes
I think some of it has to do with when the cast iron pipes were manufactured. Pipes manufactured in the in the early 1900s were probably a lot stronger than pipes manufactured in the 50s. Having worked & lived in places that were built in the 20s & before, I can tell you that the pipes lasted well over 80 years. I laugh when people say, 'I have an old house built in the 50s'. Being from NY, that's not old to me.
Adding another opinion, I wouldn't worry about them. Until you start getting back-ups or wet spots, I would assume they are all good. Cast Iron often lasts a looong time. Older homes here in PA, most of the under-house piping is cast iron, then transitions to clay a few feet outside the foundation. The clay pipes tend to have way more issues than the under-house piping.
If you're worried, I'd start setting aside some money in case something happens... but I wouldn't worry about it!
-Mike
-Mike
