Gas line and water pex line in same 4" conduit ?
Old 04-17-16, 07:46 AM
T
Hi Everyone,
I currently have a 4" PVC conduit going from my house to a detached garage. I would like to have water and gas in my garage and am wondering can I run both the gas line and the water pex tubing through that conduit, or would they need to be separated ?
I personally see no reason why not, but figure I would ask the experts.
I am in Toronto, Ontario, Canada.
Thank you,
PR
Old 04-17-16, 08:00 AM
Received 3,478 Upvotes on 3,123 Posts
Is this the same pipe as the 3" one in your other thread ?
http://www.doityourself.com/forum/el...same-pipe.html
Old 04-17-16, 10:16 AM
T
Nope it's a separate pipe. There are 2 pipes. One is 3" and the other is 4". I was going to run the electrical only in the 3" and the 4" for water and gas line.
Old 04-17-16, 06:36 PM
Z
Received 372 Upvotes on 332 Posts
Sleeving the water through isn't an issue, but using it as a gas piping sleeve, it needs to be vented. Basically if the gas pipe starts leaking, you don't want to create a pipe bomb. I don't know what the Canadian requirements are for this venting nor how it would be different from the US requirements, but at least it's a step in the right direction.
Old 04-18-16, 08:03 PM
T
Thanks for the input. I will be having a licenced HVAC specialist coming out and having a look and advise before anything else.
