Aqua Pure whole-house filter leaking after cartridge change....
Old 04-19-16, 06:17 AM
eddieo45's Avatar
Received 1 Upvote on 1 Post
I've had the Aqua Pure AP101T for years, never a problem till today. I changed the cartridge and when I reinstalled the housing it was leaking. I've removed and reinstalled it several times now, cleaning and drying the threads and o-ring, and carefully turning the water back on, but I still have a leak from the housing threads. In addition to the unit's built-in shut-off valve I have a bypass with two shut-offs installed. I have replaced cartridges many times over the years without ever having this issue. Should I try plumbers tape??
Old 04-19-16, 06:50 AM
C
Received 121 Upvotes on 97 Posts
You shouldn't need Teflon tape although you could try it in a pinch. Try replacing the o-ring; replacements are available from aqua-pure. Good idea to use plumbers grease on the o-ring.
Also, using a bright light, examine both the base and removable housing for a crack; I've had more than one housing develop a nearly invisible crack after years in service and they are hard to spot.
Old 04-19-16, 06:54 AM
Z
Received 100 Upvotes on 92 Posts
Hi eddie –
I’m not a pro but I would say you need a new O-ring. I don’t think you need tape with a good O-ring. You can buy those in a packet in Home Depot and other big box stores. I haven’t replaced the O-ring on my filter (mine isn’t the AP101T) for a long time but the last time I had a leak like yours I bought a new O-ring and that took care of it.
lol - just saw Carbide's post. I'm always late
Old 04-19-16, 10:41 AM
eddieo45's Avatar
Thanks as always for your help. I think I may have inadvertently pinched the "o-ring" gasket during my attempts to get it on and off, and that's what caused my leak. While my local Ace Hardware didn't have the correct o-ring and suggested I may need to order from Aqua Pure, Home Depot had a "kit" from GE with one o-ring that was "close enough," i.e. slightly fatter and slightly tighter. That plus the plumber's grease did the trick. The plumber's grease, for all my non-plumber DIY'ers out there, made ALL THE DIFFERENCE in getting the housing back on tight.
Old 04-19-16, 11:03 AM
C
Good to hear! and more
Old 04-19-16, 06:42 PM
Z
Ditto from me - good to hear. I think i did the same thing, got one that was close enough at HD and gave it a shot - and it worked. I'll have to remember the grease trick!!
Old 04-20-16, 07:59 AM
eddieo45's Avatar
Before getting the new o-ring, I kept trying to get it on as tight as possible. When it still leaked, I couldn't believe how hard it was to remove! I mean, I know the guy that tightened it (me) and he ain't all that strong! The grease made it easier to get tight, and I assume it'll be easier to get loose, when the time comes!
BTW, this particular filter change was a little late, and the 5 micron filter was so dirty it was affecting my water pressure!!
