water supply line size?
I am getting a typical 4/2 mobile home put out on some family land. I am being told a few different things about the size of water supply line size to run. I'm going about 900 ft from a 3/4 meter to a 3/4 house. I plan on using rolled poly. Can someone break it down on the technical side of it?
Supply Line
The plumbers will be along soon.
I would use 3/4 pipe from the meter to the m/h.
Not sure what you mean by "technical side".
Goes by fixture units
2 bath home?
Bathtub or bath/shower 4 units x 2 = 8
Clothes washer 4
Dishwasher 1.5
Hose Bib 2.5
Kitchen Sink 1.5
Lavatory 1 x 2 = 2
Toilet gravity tank 2.5 x 2 = 5
More may be added if you have whilpools are seperate showers. How about irringation system?
About 25 fixture units.
According to the plumbing chart you need a 1" meter and 1 1/2 pipe to the home.
@ 500 ft it will produce 49 units. Since you are 900 feet we divide that by 2 and get 24.5 units..
3/4 meter and 3/4 service @ 1000 ft produces only 2.5 units.. ( Your water will trickle out the faucets IMO)
And these charts are for copper.. Pex will be less as the ID is smaller.. You may need a 1 1/4 meter...
Call your water department and ask about the meter... They can easily tell you specifics on what you need to do..
2 bath home?
Clothes washer 4
Dishwasher 1.5
Hose Bib 2.5
Kitchen Sink 1.5
Lavatory 1 x 2 = 2
Thank you for the information. I just left the water dept and they pretty much told me I was forced into a 3/4 or 5/8 meter. Their main is a 3in line and "we have other big houses on this line using a 3/4 meter that works fine." Even tho I told her 900 ft run. So in your professional opinion , could i run a 2 in line from meter to the house and be good? I have a buddy that works at plumbing supply house and he asked a plumber his thoughts and he told him " 2 in is a bit overkill that I should run a 1 1/2 line off the 3/4 meter.
And possibly they have higher pressure there too.. Its a good idea to test the psi before you hook up to the home.. A pressure reducing valve may be needed.. ( You want the psi entering the home to be no more then 80 psi..)
Pex is good for 160psi @ 70F..( long term burst rating) Underground of course will be cooler.. The highest psi I ever saw in a home was 130psi so no worries there I assume...
But you never know.. with a 3 " main at the street who knows what the psi is.. You may need something at the meter if its real high psi..
Im curious to find out...
