Another toilet running thread... flapper seals but wont fill
Old 05-07-16, 06:24 AM
maarkr's Avatar
Received 23 Upvotes on 20 Posts
I'm confused (again)... I installed a new fluidmaster 400 float assembly last week. now, the water runs into the overflow tube fine, the float seems to function as it should when i manually lift it, but the tank won't fill. I checked the flapper and the seal is good, but is there another thing associated with the overflow assembly that is allowing the water to drain? I pour water into the tank and it won't fill up. Will removing the tank and tightening the overflow seal fix it? It's just odd that it started all of a sudden, so I wouldn't think the tube is cracked? or am i just stuppid about something here?
Old 05-07-16, 06:36 AM
P
Temporarily Suspended
Do you constantly see ripples in the bottom of the bowl?
Old 05-07-16, 06:40 AM
maarkr's Avatar
yes, i can tell water is coming into the toilet thru the hole at the front bottom
Old 05-07-16, 06:42 AM
P
Maybe not. Put some pressure, on it. See if the water flow stops.
Old 05-07-16, 06:48 AM
pugsl's Avatar
Received 77 Upvotes on 70 Posts
Sounds like the float is set to high. If a float on a rod. bend rod down a little. If float is around fill tube read instructions on how to adjust.
Old 05-07-16, 06:51 AM
maarkr's Avatar
pushed on it and still doesn't fill.. i noticed all the water is discharging in the overflow port under the flapper.
Old 05-07-16, 07:13 AM
Handyone's Avatar
There is no overflow under the flapper on a 'normal' toilet.
The flapper rests on and seals the flush valve. It sounds like the flush valve might be loose.
Tightening the flush valve requires removing the tank.
maarkr's Avatar
and the flow rate is very slow compared to other toilets... maybe the float assy is bad?
Old 05-07-16, 07:21 AM
pugsl's Avatar
try this shut water off. pour food coloring in tank and see if water in bowl changes color. If color changes you have a leak to bowl. either at flush valve or seal between tank and bowl.
Old 05-07-16, 07:23 AM
maarkr's Avatar
shows the port under the flapper...
this is an older toilet... maybe i just need a newer overflow assy?
Old 05-07-16, 07:28 AM
P
I don't see how a new overflow assembly would solve the problem. I still think that the flapper needs to be replaced.
Try what pugsl said.
Old 05-07-16, 07:30 AM
maarkr's Avatar
ok... colored water comes in thru the center hole in the bowl...
leak at the flush valve???
and the water level does not even cover the flapper!
Old 05-07-16, 09:20 AM
Handyone's Avatar
Agreed, replace the flapper and adjust chain properly. Forget replacing the flush valve for now.
Post a picture of the entire inside of the tank, showing how new fill valve was installed.
Old 05-07-16, 10:42 AM
maarkr's Avatar
can't believe it's working (for now)
Old 05-07-16, 12:18 PM
W
Received 61 Upvotes on 53 Posts
Flapper Chain
The chain which lifts the flapper is too long. The slack in the chain can get under the flapper and cause the flapper to not seat fully on the flush valve. Shorten the chain to where it has some slack but not enough to allow the chain to get under the flapper.
Old 05-07-16, 02:13 PM
maarkr's Avatar
yeah... i took the pic before I adjusted it... after doing this I came back later to water on the floor around the toilet base, so I replaced the entire overflow assy. Came back later with more water, so I had to tighten the tank bolts more. Then the shutoff valve leaked all over, and fortunately, i could tighten the packing nut to stop it. When will this toilet from hell ever end??? Now the seal will prob start leaking to make it a total redo!!!
Old 05-21-16, 12:07 PM
W
Flow Rate
The Fluidmaster valve needs to be flushed. Sediment in the valve will cause slow flow rate.
Old 05-22-16, 05:48 AM
maarkr's Avatar
flushed it after watching the video... when turning it on with the top removed I hardly get any water flow... see post in toilet section... Prob need to replace the shutoff valve.
Old 05-22-16, 07:21 AM
Z
Received 114 Upvotes on 105 Posts
I wonder if the flush valve seal was in bad shape, but holding, but when you installed the fill valve and had your hands in the tank, a little push one way or another on the flush valve caused it to now leak. Id replace the flush valve. I see a lot of black around the flush valve, but I guess maybe that could be sediment collecting there since that is where the water exits the tank.
Just a thought.
