Replace gas dryer - bend pipe?
Received 0 Votes
I have replaced our gas dryer. Gas inlet on new dryer is on opposite side, than the previous dryer. Copper pipe is pretty sturdy. How much can i curve the pipe to get to other side of dryer?
I have added 2 pictures\The firdt where you can see part of the dryer exhaust shows the copper pipe attached to flexible hose. Copper pipe used to go towards back left of dryer. Now i need to attach to back right of dryer. It is currently attached, but when i push dryer back against the wall, i believe that the pipe will stop it from going as far back as needed.
The 2nd picture is of the copper pipe headed up the wall towards ceiling. I have already started to curve it somewhat, to take the length out of it. How much can i curve/bend? I am doing this with my hands - no tools
Dumb ???
Thanks
Dumb ???
Thanks
Not that anything is wrong with copper, but I would dump the copper tubing and re-pipe with solid copper or iron pipe to make right angle turns and hug the wall so the pipe is not laying on the floor.
Can you somehow post a picture of how this line was run on the supply side?
I would have hard piped the regulator right to the dryer, hard piped the supply line as suggest adding a drip leg then used an elbow and shut off at the end of the supply that's attached to the wall.
If you used a long enough flex line it can be coiled and laid flat against the wall when the dryers in place but uncoils when you pull out the dryer.
Received 0 Votes
Joec - the supply line runs up above the suspended ceiling and then travels about 10-12 feet to a T junction, with main line - same size tubing. Pretty dark up there and unable to get a good picture (plus my phone died)
This is about the 3rd dryer which we have replaced since moving in, and i believe that the original dryer was directly attached to the regulator. Last dryer was installed by a plumber where he added the yellow flex tube.
PJ - Yes, it does appear that the valve is soldered on to the pipe.
For now, it appears that i can gently bend the tube to make it fit where i need it, in order to get the dryer back into it's place. Any hints on how best to bend it?
For future, sounds like the consensus would be to hard pipe the supply lines, with straight and 90-degre pipe close to the wall, and then add longer flexible tubing to get from the supply line to the dryer
Thanks
Thanks
Soft copper is just fine and is used in many parts of the US. East coast folks tend to poo poo it but I see no reason to reinvent the wheel in your case. Also, I suspect the "solder" you see is just pipe dope. You will be able to poke into it with a knife point.
