Saddle valve search
Saddle valve search
The common needle value we use when putting in a ice maker for example; DOES ANYONE MAKE THAT CLAMP ON VALUE WITH A ROUND HANDLE? The small nail size tee handle is a pain, so hard to turn in some instances and found they even bend.....why not a round handle?
Received 38 Upvotes
Those "tap" valves are a pain in the fingers as well as another part of the anatomy.
Further, they are actually prohibited by some refrigerator manufacturers for use with icemakers and refrigerated water dispensers.
I personally would never use a clamp-on tap valve.
In many areas of the country those saddle valves are no longer approved for use. In some areas they are no longer allowed for use. Every state's code is different.
tap valve
Right about whst is does to one fingers, did not know they were not ok in some areas, been used for years and truly never hwd a problem other trying to turn handle, could never understood why thst design was used .
The new refrigerators require a full port valve for the ice maker. Probably due to the filters these fridges have also..
If a old saddle valve is used the seloniods burn out in no time. I often see that happen in as little as 4 months..
And as well as not being to code anymore in many areas. NJ we cannot use them anymore.. Its been 10 plus years AFAIK...
