Leak repair advice
Leak repair advice
I noticed I have a small leak at the joint under my kitchen sink. This is likely due to me over tightening the slip nut at the P trap as it was one of my first ventures into plumbing. Or it could be caused by something else - not sure.
Anyway, I want to minimize downtime as this is the kitchen sink. Should I remove the slip joint and replace everything connected or do you think I may have to cut the pipe out of the wall?
The mess in the pic is greasy. It seems like this was a slow leak as its been almost 8 years since I did it:
Thanks
Thanks
I would probably cut it close to the elbow, leaving as long of a piece as you can coming out of the back of the cabinet. Then glue on a 1 1/2" slip adapter. Looks like this:
1-1/2 in. PVC DWV Hub x SJ Trap Adapter-C48017HD112 - The Home Depot
Then add a new 1 1/2" p trap... looks like this... Everbilt 1-1/2 in. Plastic P-Trap-C9704B - The Home Depot
And you might need a new short tailpiece to extend your existing tail piece. Looks like this: Everbilt 1-1/2 in. x 6 in. Polypropylene Slip-Joint Extension Tube-C9792 - The Home Depot
So you would remove everything below your existing tailpiece... all the way to the last elbow.
You might also want to fix that dishwasher drain pipe so that it is looped up as high as possible on the back wall of your cabinet.
Those nuts often crack from overtighening..
If the nut is not cracked your best bet is to teflon paste the heck out of the two mating surfaces and the nut threads.
Then only snug the nut tight till it stops leaking..
If the nut is cracked then full replacement is in order..
I would not buy a LA trap as you show and would convert it to a regular p trap...
Thanks guys. I'm a fan of fixing it right so I would rather replace.
My issue is the ptrap linked - those tend to be cheap flimsy plastic do dads. I prefer to have the schedule 40 (?) elbow.
What is an LA trap? Is that what I'm referencing.
The traps linked ar 1 1/2". I've got 2" there now.
Do they make 2" ptraps? Should I only have 1 1/2".
Received 38 Upvotes
1-1/2 inch traps are standard for kitchen sinks although code now requires the piping in the wall to be 2-inch. I would start at the wall by cutting the 2-inch and gluing on a 1-1/2 inch trap adapter. Run the rest with standard 1-1/2 inch PVC drain tubing with slip nuts.
The wall pipe is 2" so I'm good there. As far as cutting, what's the best way to get a strait cut in a confined space? When I work with PVC I'll typically put the piece on my electric miter saw.
And it seems people here prefer the ptrap rather than the setup I have. I'm curious as to why - is it better in some way?
Should I be concerned about drainage going 1/2" smaller? At the time I was told 2" was required for the kitchen and 1.5 for bathrooms. Was I misinformed?
My main concern is it can get banged up down there from getting cleaners and what not and a thicker larger pipe would handle it better.
That's not much of a leak after 8 years. I see the stain on the cabinet floor and I see the same stains at the top of the trap.
Are you sure the leak isn't coming from above? Maybe the basket strainer is leaking?
I'm going to agree with Brian, stains on TOP of the trap indicate that the leak is from above. Looks like your dishwasher drain line has fallen and the corrugate hose may have lost its seal. Dishwasher drain lines should be raised to above the connection to the tail piece.
Received 38 Upvotes
