Small drip from under newly installed pressure tank
Can't figure out if it's the sweat from the tank dripping or a leak in the pipes.
Presumably if it was humidity, it would stop dripping after a few hours?
Is the humidity high today? Wrap a paper towel around the pipes. Then look carefully at the solder fitting. You can try using soapy water and a brush. The pressure will cause the soapy water to bubble a bit if it is fact a leak.
