NPT Pipe options for Rough-in shower valve
Apologies if this is a newb question but I'm still learning US fittings...
I have a rough-in valve from Kohler (K304) to fit.
I got the one with NPT threads to give me some options, but I'm still a bit stuck as to what to chose without having to learn to solder...
I was going to use R/A Sharkbites on there, but the pipes will need to exit parallel to the tub outlet, and with teflon tape the fitting does not to up really tight. If I tighten it harder the exit pipe comes out at a wacky angle.
Will that leak if I don't tighten it fully? I can use pipe-ope and/or tape?
What other options are there. Can you get screw on brass fittings with compression to copper?
Thanks
Thanks
If you are doing new piping I would consider pex and use their crimping system. You already found out the $8 Sharkbite is expensive
Rather than using teflon tape, consider using Rectorseal T plus 2. It is teflon based but you will have fewer leaks with it.
Received 100 Upvotes
I’m no expert for sure. But are you saying you are trying to do Step 4 as depicted on page 9 of the referenced document - but when you tighten the Sharkbite elbows in tight to the valve, you then can’t connect the vertical copper supply pipes (as in the diagram 4 on page 9) into the Sharkbite elbows because they won’t line up?
http://www.us.kohler.com/onlinecatalog/pdf/114811_2.pdf
Did you trace the supply pipes back through the floor? There might be pipe straps or something you could remove to give you a little play in the pipes.
I cheat a little sometimes and add a little extra tape if I want something to tighten up sooner. I don’t know whether the plumbers would approve of that, but I’ve done it without leaks.
(I also use the trick many plumbers use – pipe dope over the tape. Works for me, no drips.)
Yes this is to get the hot and cold into the valve, so Step 9.
If I use this NPT to R/A sharkbite fitting and I tighten it up by hand fully the pipe is at a wacky angle. I did think about using lots of tape and/or dope to make it tighten "earlier".
I'm not sure if that's an approved method either!
You don't tighten only hand tight. You must use a wrench to complete it. That may give you the angle you want. If it doesn't, then use a straight sharkbite/ipf, add a length of pipe and use a double sharkbite elbow to make it perfect.
Why don’t you just open the holes a little more where the supply pipes enter the wall to create the alignment needed?
p.s. just saw this link, and Lawrosa is a real plumber!
http://www.doityourself.com/forum/pl...-fittings.html
