grounding a water main supply?
Old 06-26-16, 07:40 PM
DIY1968's Avatar
Does a water supply line made of ADS and/or PEX need to be grounded? like the metal water lines. Thanks
Old 06-26-16, 08:16 PM
Received 125 Upvotes on 110 Posts
Guess you mean ABS, there is no way, or need to ground plastic pipe.
Received 3,485 Upvotes on 3,128 Posts
Did you mean ABS ? ADS = advanced drainage systems and is drain pipe as far as I know.
You don't ground the water system. You bond your panel to the metal water service line.
Since you have no metal.... there is nothing to bond to.
So in that case.... I'd recommend having two grounds for the service.
Old 06-26-16, 08:35 PM
DIY1968's Avatar
Thanks for the help folks!!
