connecting branch drains to trunk?
I am repiping my DWV with a 3" ABS trunk. Should the drain lines from my sinks, washer, toilets, etc. attach on the side of the 3" trunk, the top of the trunk, or on a 45 degree angle into the trunk? I was planning on using wyes or long sweeps on the side of the trunk as long as the fixture drains are 1/4" over a foot slope. What is correct? I was also told a DWV pipe can be between 45 and 90 degrees, but no less than 45. Is this correct? thanks!
It doesn't matter if drains connect horizontal, vertical or somewhere in between on a horizontal main drain. You'll need to use wyes (or combo wyes) for all the connections. Sanitary tees are allowed only when going from horizontal to vertical.
I don't know what code specifically states as a maximum angle. I've read that you should always keep them vertical or horizontal (with the 1/4" fall). Between that you run the risk of the water moving faster than the solid waste. But I'm not sure if it's specifically against code or just a recommendation.
