How far must frost free faucet extend in?
Old 08-07-16, 06:17 PM
Q
Received 1 Upvote on 1 Post
Is there any code as to how far the anti freeze pipe must extend into a warm area for it to work?
They work by draining the water out of the pipe but that little connection point at the end where the pex connects always has pressurised water. If that gets cold then the metal pipe could rupture.
I have an 8" pipe for an 8" concrete wall and plan to insulate the pipe in the wall with foam.
Old 08-07-16, 06:24 PM
Received 125 Upvotes on 110 Posts
Need at least a 12" to be able to connect it to the plumbing.
Always best to also install a ball valve so the water can be shut off for service so you do not have to shut the whole house off.
If it stays below freezing in that crawl space that foam is useless.
Old 08-07-16, 07:36 PM
Q
Not a crawl space, it's a heated entrance room.
Why 12"?
I can just connect a pex pipe to it with a 90 degree bend. Needs about 1" extra and even that connection can be almost flush against the concrete, no?
Old 08-07-16, 08:48 PM
Received 3,488 Upvotes on 3,131 Posts
Why 12"?
Because you want the actual valve, which is on the supply connection end of the faucet, to be completely inside the heated area. A 10" valve would also be ok if you could find one.
