PVC piping for pool
Old 08-18-16, 08:52 PM
P
PVC piping for pool
Am going to work on 2" PVC. Some questions from a homeowner who has never done plumbing before of any kind other than shower faucet installation.
This is for my pool. I have 2 questions:
Q1:
I have PVC piping which is painted matte black. Will need to remove enough of it to fit a coupling. If I don't remove it I may compromise the installation and see a leak.
How to remove the paint? Safety to me is important. I don't want to breathe anything toxic.
Q2: What is the min surface area necessary to get a reliable bond? What I mean is how long along a pipe in terms of inches is necessary for me to bond a fitting. I have a section with less than one inch (maybe 3/4 inch) and I am wondering if I can get a successful bond there?
Old 08-18-16, 09:12 PM
Received 3,481 Upvotes on 3,126 Posts
Use sandpaper, a file or a knife to scrape the paint off.
Like I mentioned in your other thread.... the paint doesn't usually stick that well.
You need a piece of pipe equivalent to the length required to slide into each fitting. That would be approx 1/2"-3/4" inside each fitting. A total stub length of 1-1/2 to 2" long. The two fittings can touch each other.
Name:  20160723_074801 - Copy - Copy.jpg
The blue illustrates the stub. It needs to be fully inside both fittings. You should install A first. Then your stub(blue) then B.
Originally we discussed splitting B but if you're asking about black paint I'm guessing you're going to be cutting the pipe somewhere by the green line and using a coupling.
You can also install a 2" union in place of the coupler.
Old 08-18-16, 10:16 PM
ray2047's Avatar
Just be aware most two inch fittings sold by stores like Home Depot are not pressure fittings. They are drain fittings and will blow apart. The pressure fittings have a much deeper socket for the pipe.
Old 08-18-16, 10:36 PM
I probably should have combined the threads but the other one is getting a little long.
http://www.doityourself.com/forum/po...ound-pump.html
Good point on the fittings Ray. I believe I mentioned getting the fittings from a pool supply store in the other thread.
Old 08-18-16, 11:58 PM
ray2047's Avatar
Many hardware stores will have them too.
