Liquid Wrench silicone spray to quiet copper pipe?
Old 09-16-16, 08:47 PM
Q
Received 1 Upvote on 1 Post
Hello all,
I found my copper pipe(hot water) generates some noise due to expansion. The pipe goes through a hole on 2x6 without any gap on one side and generates friction noise when someone uses the shower.
Can I use Liquid Wrench Silicone Spray to lubricate the wood and copper pipe and solve the noise issue?
Thank you
https://www.menards.com/main/tools-h...4451781964.htm
Old 09-16-16, 09:08 PM
Received 4,088 Upvotes on 3,671 Posts
Silicone spray may work but would only be a very temporary repair as the silicone would be absorbed into the wood.
You should be able to move the pipe away from the wood and slide something in like a piece of tubing or vinyl. Something to act as a slide plate. Improvise.
Old 09-17-16, 05:01 AM
Tolyn Ironhand's Avatar
Received 899 Upvotes on 760 Posts
Cutting a plastic food container from the store (yogurt, cool-whip, cottage cheese) and slipping it between the pipe and wood would likely work.
Old 09-17-16, 09:34 AM
Thanks Scott..... I was trying to think of what was easily available.
