Prepare for conceal inspection
Old 10-02-16, 05:51 AM
Y
I scheduled county plumbing conceal inspection next Friday for a kitchen in finished basement. County uses IRC2012 code.
I have one CSS gas pipe in concealed wall and ceiling with pressure gauge tested at 5psi.
I have non-concealed dry fit PVC drain pipes for Kitchen sink and washing machine with AAVs (photos attached).
I don't want to be surprised by the inspection, how should I be prepared for the inspection?
Thanks advises in advance.
Old 10-02-16, 06:21 AM
ray2047's Avatar
Top picture: The black ell is not part of the original P-trap. That is a surface to surface seal, no sealing ring, for that part of the P-trap. Will it seal?
This is what it should look like:
Old 10-02-16, 06:16 PM
Y
I was too lazy to cut the J pipe in the AAV kit and used a J pipe from a garbage disposal.
I replaced the black J pipe with the J pipe from the AAV kit.
Thanks.
Old 10-02-16, 07:22 PM
ray2047's Avatar
Looks good. .
