Basement rough. Need help with pipes.
Old 10-08-16, 11:30 AM
A
Hello,
After looking around quite a bit, I think I figured out most of this basement bathroom situation, but I'm still stumped on one part of it.. or maybe all and I'm just way off.
What I think I know..
I've got a shower pit, toilet, and sink in a line on the left.
A vent stack access above and one coming from the floor.
A cleanout on the back right.
But then there's this other tube.
- Black, about 4 inches. And there's a threaded cap down it. It's down below the floor line.
Is that just another cleanout?
If so, do I need access to both of them? (they're less than 2 feet apart.
Thanks for looking.
Old 10-08-16, 01:08 PM
A
Cleanout
Yes, that's what it looks like. I
Old 10-10-16, 12:28 PM
Z
Received 398 Upvotes on 355 Posts
Welcome to the forums!
The cutout at the top left looks like it could be a tub drain instead of a shower drain. The way to tell for sure is whether it's 1.5" or 2" pipe. 1.5" pipe must be used with a tub. 2" is usually shower, but can be used for either.
The black cleanout may be a cleanout for a underground french drain or storm drain. Since it's a different material, it doesn't seem like it would be a sewer cleanout. I would assume it needs to be left accessible.
Does the vent from below connect to the vent to ceiling/roof? Usually that's where the sink would be connected in. It's odd that you'd have an additional sink drain that doesn't come up into the wall.
I know this doesn't answer all your questions, but hopefully it helps a bit.
-Mike
